Activity Forums Avid Media Composer Consistency Check Failure
  • Consistency Check Failure
    Posted by Timothy Lydon on September 15, 2014 at 5:36 pm
    Hello everyone!
    I am having a problem with a video clip that I shot on a JVC700. I linked it into Avid then transcoded it along with a number of other clips that work. But about 30 seconds into this clip AVID shuts down and this screen pops up:
    LongGODDecodeState:: Execute()
    CONSISTENCY CHECK FAILURE !?! : [2]
    I tried re-linking it, renaming it, putting it a different folder, renaming a bin in Avid, bringing the same clip from another hard river and nothing has worked.
    Any ideas?
    Tim
    Timothy Lydon replied 11 years, 11 months ago 2 Members · 2 Replies
  • Bruce Carter
    September 16, 2014 at 5:30 am
    I’ve seen consistency check failures before when a clip was corrupted due to a glitch that occurred during transcode. Verify the original file is not corrupt. Can you use it via AMA-linking or via import with a fresh transcode? Try to isolate the part of the clip where the error occurs and cut around it. The rest of the clip may be fine.
  • Timothy Lydon
    September 19, 2014 at 12:17 pm
    Thanks for responding, Bruce.
    I’m guessing the original file is corrupt because I have it saved on other hard drives and I have copied it over to my project and none of them haven worked. I did try with a fresh transcode and that didn’t work either. Unfortunately the part where it cuts out is an interview that I need. It’s strange after the “CONSISTENCY CHECK” tab comes up, AVID shuts down and when I reopen it it was like the file was never even there.
    Timothy
