Activity Forums Sony Cameras Considering Shooting on Sony HDW-F900 got ?’s
  • Considering Shooting on Sony HDW-F900 got ?’s
    Posted by Eric Jones on September 26, 2007 at 3:10 pm
    Thanks Forum Directors and Readers in Advance,
    Our Team is considering an aerial shoot using the Sony HDW-F900. We Have an AVID Media Composer and an AVID Mojo with HD Xpress. I’ve never done HD before, but We also have AE and Premiere Pro CS3. With these tools can we import footage and downcovert properly to a SD format?
    thanks
    ejunyor
    Eric Jones replied 18 years, 11 months ago 3 Members · 4 Replies
  • Steve Wargo
    September 27, 2007 at 5:25 am
    [ejunyor] “With these tools can we import footage and downcovert properly to a SD format?
    You’ll need a playback deck like a JH3 and you’ll be good to go, hoping that you have all of the usual tools for importing broadcast footage.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    Sony HDCAM F-900 & HDW-2000/1 deck
    5 Final Cut Pro systems
    Sony HVR-M25 HDV deck
  • Eric Jones
    September 27, 2007 at 6:19 pm
    thanks Steve
  • Jeremy Newmark
    September 30, 2007 at 12:32 pm
    Keep in mind that if you are ingesting and editing with the Avid’s, you can only ingest the content in SD from the downconverted signal coming out of the JH-3. So it will be an SD workflow, not an HD workflow that you would then downconvert at the end. To ingest HD into an AVID from HDCAM tape you need at least an Media Composer Adrenaline with the DNxcel HD board, which will let you work with the compressed DNxHD codec. Or you need an Avid Symphony Nitris or DS system to ingest the HD in uncompressed.
    On the other side if you are using Premier Pro for ingesting and editing, then you simply need the appropriate AJA or Blackmagic card and fast enough storage to work with HD.
    best regards,
    jeremy
  • Eric Jones
    October 1, 2007 at 3:47 pm
    Thanks Jeremy,
    We do have Media Composer Adrenaline, but not sure if we have the card in which you speak (I’m not using that machine), but thanks for the info as I am sure we will be moving in that direction soon. For now we are just looking to take that footing and ingesting an SD signal. NO need to edit or output HD for now…
