Activity › Forums › DSLR Video › Considering getting a few old prime lenses off ebay,,,
Douglas Patrick replied 15 years, 6 months ago 9 Members · 15 Replies
Micah Mcdowell
January 3, 2011 at 4:01 pmOn my 550D, I started with a Olympus 50mm f/1.8 prime using an adapter from eBay member “kawaphoto”. Cheapest adapter around, but it worked flawlessly. Now I’m using a m42 screw-mount Fujica 50mm f/1.4 with another kawaphoto adapter. It also works great, but I had to file off a tiny tab on the lens before it would fit properly. Also have some Olympus and Fujica zooms/teles that work well.
Old manual primes and adapters are the way to go if you’re on a budget. I’ve got about $30 (!) invested in my 50mm prime and I now use it exclusively unless I need a wide-angle or have to change framing quickly. It makes it feel like I could shoot by candlelight. Be sure to look at local thrift stores, pawn shops, and estate sales for these old lenses. I’ve bought all mine that way. When I find something better, I eBay the old ones for a profit.
Michael Lorushe
January 4, 2011 at 1:28 pmGreat stuff…thanks for all the information guys. Really appreciated.
Michael Folorunsho – Videographer & Editor
http://www.mikedoesmedia.com -
James Navarro
January 27, 2011 at 8:16 pmI am considering using prime lenses for my camera, but I do not know much about lenses. I see all these different series like e or fd, I have no idea if they would be good for video work. I stumbled across this sellers store on ebay, and he has several older lenses: https://stores.ebay.com/Rokas-Photo-And-Video/_i.html?rt=nc&_nkw=lens%20FD&_sid=32443323&_trksid=p4634.c0.m14.l1513&_pgn=2. I would like to get a 28mm and a 135mm. I am using the 7d and t2i, would any of these prime lenses be good. Thank you!
Micah Mcdowell
January 27, 2011 at 8:31 pmIt appears that every lens that seller has listed is specifically what you do NOT want to use on a Canon 7D or T2i.
They are all Canon FD lenses (FD being the mount that Canon used before the modern EOS autofocus cameras). Almost every vintage camera mount from every manufacturer is easily adapted to a Canon DSLR; ironically, Canon FD is one of the few that are impossible to adapt usefully. They can be mechanically adapted, but the flange distance is too deep so it’s impossible to focus to infinity. You don’t want this. Lenses that are easily adaptable with mechanical rings from eBay are old Pentax K-mount, Olympus mount, Nikon F-mount (manual focus only), Fujica/Fujinon (what I use), M42 screw mount, and many many others. And, obviously, any Canon EOS (EF or EF-S) lenses will work… no adapters needed.
So to answer your question, all of the lenses that seller has would be terrible.
Douglas Patrick
March 4, 2011 at 8:43 amso, a standard eos 35mm lens will work on a 7d with no adapter needed?
never play leapfrog with a unicorn
