Connection set up with MiniDV
I’m in the process of up-rezing 720X480 to 720X486 Apple Pro res(HQ). I did a test on on project and the picture was obviously better in color and maybe slightly sharper. I think the blacks came out a little more richer, I don’t know. After uprezing a 24P project, it looked good.
I have the MiniDV deck connect via S-video through 2 BNC into AJA Kona LHe.
I decided to try it on another project shot 24pA re-digitizing to a higher quality. Hoping I can have a higher color space in color correction. The picture is much darker this time. It was as if the Black level went down 7.5 IRE. In the AJA control panel, it’s set to 7.5 IRE.
Viewing a 720×480 DV media capture via firewire and switching the IRE level to 0, it would look like how I digitized it via BNC connection. Is this normal? Does it matter between 24P vs. 24pA?
I’m wondering if my connection is setup properly. Is there something in Final Cut Pro setting that I may have missed?
Hope this makes sense.
