Activity Forums Canon Cameras connecting XHA1 to HV40
  • connecting XHA1 to HV40
    Posted by Shawn Riley on November 25, 2010 at 8:21 pm
    Hello all, i am trying to make a copy of a mini dv tape from one camera to another. When i connect the two together using firewire its seems nothing happens. I put the HV40 on “play” and the XHA1 on “record” but it will not work. It seems like the two cameras are not reading each other. Is there something I need to do in the menu to make the cameras read each other ? Thanks for the help !!
    Shawn Riley
    Brian Louis replied 15 years, 9 months ago 2 Members · 1 Reply
  • Brian Louis
    November 25, 2010 at 10:26 pm
    Both camcorders should be in the Play mode, setup properly, look under “Digital Video Dubbing” in your HV40 owners manual and “Recording External……..” in the A1 manual
    Make sure the modes and formats are setup properly before connecting the camcorders via firewire.
