Activity › Forums › Adobe After Effects Expressions › Connecting Two Keyframes To Start And End Point of Workspace
  • Dan Ebberts
    February 6, 2022 at 6:48 pm
    Do you mean the work area? Expressions don’t have access to the work area start and end times. Scripting does, so you could do it with a script, but it wouldn’t adjust automatically when you change the work area.
  • Kamiar Babaei
    February 6, 2022 at 7:00 pm
    Yes, work area,
    Than maybe the script can have a refresh button for when I want to update it to the new work area length?
  • Dan Ebberts
    February 6, 2022 at 7:54 pm
    It could, but that would require a UI for the script, which is a bit of work. Here’s how the basic functionality might look though:
    function setKF(){
    var myComp = app.project.activeItem;
    if (! (myComp && (myComp instanceof CompItem))){
    alert("No comp active.");
    return;
    var myProps = myComp.selectedProperties;
    if (myProps.length == 0){
    alert("No property selected.");
    return;
    var myProp = null;
    for (var i = 0; i < myProps.length; i++){
    if (myProps[i].numKeys >= 2){
    myProp = myProps[i];
    break;
    if (myProp == null){
    alert ("No property with 2 or more keyframes selected.");
    return;
    var tStart = myComp.workAreaStart;
    var tEnd = tStart + myComp.workAreaDuration;
    var myExpr = "t = linear(time," + tStart + "," + tEnd + ",key(1).time,key(numKeys).time);\rvalueAtTime(t)";
    myProp.expression = myExpr;
    setKF();
  • Kamiar Babaei
    February 7, 2022 at 10:22 am
    Thank you so much.
