Activity Forums Apple Final Cut Pro Legacy Connecting TV monitor to computer to test PHOTOSHOP text
  • Connecting TV monitor to computer to test PHOTOSHOP text
    Posted by Mike Kranyak on February 25, 2006 at 2:56 pm
    I have producers/clients who create text for me in PHOTOSHOP. Would like them to view their work on a TV monitor before saving and sending them to me. WHat’s best way to connect monitor to computer…..? thanks.. mike k.
    Ed Dooley replied 20 years, 6 months ago 4 Members · 6 Replies
  • Ed Dooley
    February 25, 2006 at 4:56 pm
    DO A SEARCH! There are tons of postings about this all over the COW. Here’s a couple, but c’mon
    just type “connect TV to computer” and you’ll see, um, A TON!
    Ed
    https://www.matrox.com/video/products/rtx100xtremepro/home.cfm
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=8&postid=882641
  • Mike Kranyak
    February 25, 2006 at 5:08 pm
    sorry Ed to take up time…. kinda new on CC and didn’t know i can do a search….will do it from now on. thanks !!!!
  • Bryce Whiteside
    February 25, 2006 at 5:25 pm
    AJA Video – Serial Digital Video Interface and Conversion has Kona SD, Kona 2 and Kona 3 boards depending on the model of Mac and its PCI, PCIx or PCIe your clients have. These definitely work with Adobe After Effects and Photoshop. They might just need one of AJA’s IO’s which can be attached externally through a firewire port. The IO’s are around $1000. Check their forum here.
    I believe, but can’t confirm the lower cost Blackmagic Design cards do this also. I don’t know why they wouldn’t since they wrote the drivers for the original AJA Kona cards.
    I am less familiar with the Aurora Video Systems products.
    All of these manufacturers have a forum here at the Creativecow.net so you can post a query in their forums.
    Now the big question is how long you will remain just doing SD video or when you are going to move to HDTV resolutions.
    HTH,
    Bryce Whiteside
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Mac OS X 10.4.5 QuickTime Pro 7.0.4
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
    After Effects 6.5
  • Jeff Carpenter
    February 25, 2006 at 5:28 pm
    All of these cards being suggested to you can do all sorts of great things, but IF you have Photoshop CS2 and IF you are editing in DV-resolution, then you can simply use a firewire camera or converter to view your photoshop images on a video monitor.
    Granted, that’s two “ifs” but it’s worth pointing out, all the same.
  • Bryce Whiteside
    February 25, 2006 at 6:18 pm
    Excellent point Jeff.
    To quote Adobe Photoshop CS2 Help Menu:
  • Ed Dooley
    February 25, 2006 at 6:57 pm
    No problem. It’s a pet peeve of mine. As long as it helps you learn all the resources of the COW, I’m happy.
    Ed
    [mike kranyak] “sorry Ed to take up time…. kinda new on CC and didn’t know i can do a search….will do it from now on. thanks !!!!”
