Activity Forums Apple Final Cut Pro Legacy connecting to external montior – stuttering!
  • connecting to external montior – stuttering!
    Posted by Elise London on November 23, 2009 at 6:15 pm
    I am trying to connect to an external monitor to run my DV NTSC sequence out of FC7 on my Macbook Pro. I am running the video out to S Video into the monitor.
    In Final Cut, when I choose ‘view –> video playback –> Digital Cinema Desktop Preview – Full Screen’ and ‘External Video –> All Frames.’ The sequence plays fine in the canvas, but on the external monitor, it stutters.
    When I change to ‘External Video –> Off,’and drag the canvas over to the external monitor, it seems to play without stuttering, although it does seem to have the odd artifact every now and then.
    Is there a setting somewhere that I am missing?
    Michael Sime replied 16 years, 7 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    November 23, 2009 at 9:07 pm
    It’s not a setting, it’s a piece of gear you need… any DV camera would do it for you. Just run a FW cable to it, then set it to it’s VTR settings, and then run the analog outs to your external monitor. then set the system to the DV easy setup and you’re good to go.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Arc Nevada
    November 25, 2009 at 2:17 am
    It is true. You can loop through your DV camera or use a DV converter. Some DV converters will give you full deck contol with the older 3″4 inch decks and Beta decks. DV converters will also have more I/O options.
    https://www.youtube.com/watch?v=Oj0JoFxoOyo
  • Michael Sime
    January 29, 2010 at 10:33 pm
    sounds like you’re having a problem many have been seeing after the latest update of FCP 7….
    it’s discussed (& fixed) here-https://forums.creativecow.net/thread/8/1059834#1059834
