Activity Forums Maxon Cinema 4D Connecting Polygons after using the Loop/Path Cut
  • Connecting Polygons after using the Loop/Path Cut
    Posted by Don Lavender on February 6, 2019 at 12:57 am
    Hi All. Is there a way to connect multiple polygons after they’ve been separated by the loop cut tool that are on the same plane? There appears to be multiple options that result in creating a N-gon. But sadly, it’s not possible make new cuts on such on N-gons.
    Thank you for helping a with this simple question.
    Don Lavender replied 7 years, 7 months ago 2 Members · 2 Replies
  • Brian Jones
    February 6, 2019 at 3:35 pm
    Loop/Path Cut settings – Interaction tab – uncheck Stop Cut At N-Gon
  • Don Lavender
    February 12, 2019 at 4:56 pm
    You’re my personal hero of the day Brian. I will be sharing this story with all. ;D
    Many thanks Sir.
