Activity › Forums › Adobe After Effects Expressions › Connecting movements inside of a mask to a slider
  • Kamiar Babaei
    May 1, 2021 at 5:29 pm
    UP
  • Dan Ebberts
    May 1, 2021 at 10:44 pm
    You could set up an expression for your mask path, where the height is based on the slider value. This example is more complicated than it needs to be, because I wasn’t sure whether your path goes clockwise or counter-clockwise so the expression allows for either:
    s = effect("Slider Control")("Slider");
    p = thisProperty.points();
    if (p[1][0] < p[3][0]){
    p0 = p[3] - [0,s];
    p1 = p[2] - [0,s];
    newP = [p0,p1,p[2],p[3]];
    }else{
    p0 = p[1] - [0,s];
    p3 = p[2] - [0,s];
    newP = [p0,p[1],p[2],p3];
    createPath(newP,[],[],true)
  • Kamiar Babaei
    May 2, 2021 at 9:38 am
    Thank you so much for this awesome expression.
    But what i meant was the white bar inside of the mask is going to move vertically and i need the slider to acknowledge it and set a value to it between 0-100 based of the size of the mask.
    is it possible?
    thank you so much and sorry for not explaining properly what i wanted at first, i didn’t how to say it.
  • Dan Ebberts
    May 3, 2021 at 10:09 pm
    The only thing I can think of would be to use sampleImage() (with postEffect=true) in a loop, starting at the top of the range and moving down (1 pixel at a time) until you find a pixel with non-zero alpha to determine the current height of that bar. Then use that value to drive the height of the mask.
