Activity › Forums › Adobe After Effects › Connecting lines to each points in a shape
  • Connecting lines to each points in a shape
    Posted by Morten Torgersen on October 15, 2018 at 6:25 pm
    very on/off with using AE so I probably are loosing the basics here. But I want to have 4 lines connected to each corner of a smaller rectangle while the other end of the line is fixed to each corner of a bigger rectangle. So when I move (or scale) the inner smaller rectangle the 4 lines follow.
    I got stuck on the beam effect with some dots and lines tutorial but I couldn’t manage to apply that to this project. I was going down a path of creating nulls for each point but I figured it must be an easier way of achieving this?
    I added an image where the inner rectangle has 3 different positions just to show what Im aming for
    thanks,
    Morten
    Kalleheikki Kannisto replied 7 years, 11 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    October 16, 2018 at 8:07 am
    Since the inner rectangle is the one moving, you should need just four nulls, parented to the rectangle. Keep one end of the beam effect at the appropriate corner of the larger rectangle. You will likely need the following expression to convert the parented null’s position to world coordinates for the position of other end of the beam. Change null layer name to reflect the actual names of you corner nulls for each beam.
    L = thisComp.layer("null 1");
    L.toWorld(L.anchorPoint)
    Senior Graphic Designer
