Activity Forums AJA Video Systems connecting An AJA kona 3 output to FCS Colour
  • connecting An AJA kona 3 output to FCS Colour
    Posted by Simon Fuller on January 19, 2011 at 8:13 pm
    I am hoping to get some advice. I have, in my edit suite a broadcast monitor that receives an output from Final Cut pro V 7. Is it possible to revive onto the broadcast monitor an output form Colour. this would be most handy for grading. Currently I am using the component out of the K3 for final cut pro 7 . I also have access to units SDI outputs if that helps. Any ideas would be grateful
    Cheers
    Simon Fuller Cameraman
    https://www.simonfullerpictures.tv
    Simon Fuller
    Lighting cameraman
    Simon Fuller replied 15 years, 7 months ago 2 Members · 2 Replies
  • Richard Cooper
    January 19, 2011 at 9:50 pm
    You bet, Simon.
    In Color, just go to the Setup tab and they the user tab then chose your Kona Card in the video output drop down menu. This should send your video out through your Kona for proper monitoring.
    Hope this helps!
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Simon Fuller
    January 20, 2011 at 6:06 am
    Thank you Richard, for your help. Much appreciated.
    Simon Fuller
    Camermaman
    Simon Fuller
    Lighting cameraman
