Activity Forums Apple Final Cut Pro Connected multi layer psd and audio
  • Connected multi layer psd and audio
    Posted by John Watts on January 22, 2019 at 9:46 pm
    Have created and layed on the sequence a multi layered psd and want to edit it to music. If I add the connected file and open it up for adjusting lengths, the audio goes away. I need to edit these texts to audio. Hmmm..
    Thx
    John Watts
    Premiere Pro Version 12.1.2 Build 69
    2017 iMac (Retina 5K 27 inch) 1TB SSD
    4GHZ Intel Core i7
    32GB 1867 MHz DDR3
    Graphics AMD Radeon R9 M395X 4096 MB
    macOS High Sierra Version 10.13.6
    Oliver Peters replied 7 years, 8 months ago 2 Members · 2 Replies
  • John Watts
    January 22, 2019 at 10:45 pm
    I exported the layers as individual images and it worked fine. I thought the elegance of a multi-layer psd would shine through?!?
    John Watts
    4GHZ Intel Core i7
    32GB 1867 MHz DDR3
  • Oliver Peters
    January 22, 2019 at 11:33 pm
    Isn’t that file inside FCPX a compound clip? If so, that’s like a nested sequence in Premiere. So when you step into the compound, you won’t see or hear what was in the sequence “above” or “outside” of it until you step back out.
    – Oliver
    Oliver Peters – oliverpeters.com
