Activity › Forums › Audio › Connect USB interface balanced output to ZOOM H5
  • Richard Crowley
    September 12, 2016 at 4:18 am
    #1 is the prefered method. As you say, your Roland Tri-Capture has a balanced, line-level output. And the Zoom H5 TRS inputs (part of the XLR/TRS “combo” input jacks) will accept LINE-LEVEL audio when the H5 is configured properly.
    Note you are NOT connecting to the H5 “mic-input”. You cannot connect ANY line-level audio signal to a mic-level input. Note also that whether a signal is balanced or not is quite independent on the signal level (mic-level, line-level, etc.)
    #2 is neaarly the same as #1 except that it uses an UN-balanced signal. While that may work just fine in many cases, there may be some situations where the balanced connection’s ability to reject ambient noise could be a big advantage. No particularly good reason to use unbalanced cable (TS) when you have a proper balanced source and a balanced destination. Of course, if you had an unbalanced source (which you DO NOT) and a balanced destination, then using an unbalanced TS cord would be preferable.
    #3 is NOT likely to perform as well as #1 (or even #2). The headphone output of most gear is not designed to the same standards of quality as the main output.
    Recording audio without metering and monitoring is exactly like framing and focusing without looking at the viewfinder.
  • Gami Rosd
    September 12, 2016 at 6:54 pm
    Thanks for your detailed reply.
    If I am going with option #1, what is the settings for Zoom H5 I should use? as I am really very confused for how to adjust it.
    Does the MIC 1 & 2 inputs for Zoom H5 TRS are balanced or not?
    GR!
  • Richard Crowley
    September 13, 2016 at 2:27 am
    I am confused, also. Somehow in 116 pages of English-language manual they never actually explained the TRS inputs of the combo “1/2 INPUTS”. So it is not at all clear whether the 1/4 TRS inputs can be used as line-level, mic-level or instrument-level. This is a gross failure on their part, but unfortunately it is all too common for this pro-sumer gear to have documentation that is so “dumbed-down” it is practically useless.
    Upon closer inspection of the (poor) documenation, it appears that the only input that is identified as “line-level” is the 3.5mm “MIC/LINE input jack” on the upper right side. That means you would need to use a “stereo break-out” cable like this to connect the outputs from your Roland Tri-Capture to the 3.5mm TRS “MIC/LINE input jack” on your H5.
    https://hosatech.com/product/cmp-150/
    This is just one example from Hosa. There are many other similar cables that would work exactly the same.
    I found the manual here: https://www.zoom.co.jp/sites/default/files/products/downloads/pdfs/E_H5_0.pdf
    And on page 98 is the only information I found on configuring the H5 for line-level input.
  • Gami Rosd
    September 13, 2016 at 5:43 am
    Thanks a lot.
    I will order this type of cable and try it and feed you back.
    Note: When you typed this pro-sumer gear, you mean that Zoom is not a professional digital recorder? in that case, which brand and model considered a professional digital recorder?
    GR!
  • Gami Rosd
    September 13, 2016 at 7:04 am
    Just another quick question before I place my order for the cable you recommended.
    As far as I understand the Line-In input in the Zoom H5 is stereo and balanced and this is why we are using a Stereo Mini 3.5mm Male.
    Regarding the USB interface out, according to my understanding it is Balanced which mean it should be a 2 Stereo 1/4″ Male, right!?
    So the right required cable should be a (Stereo Mini 3.5mm Male) =TO> (2 Stereo 1/4″ Male) and not 2 Mono 1/4″.
    So did I understand it correctly or still confused 🙂
    GR!
  • Richard Crowley
    September 13, 2016 at 4:18 pm
    The Zoom “H” series is pro-sumer at best. However, recently Zoom have started making a couple of more professional-level products, the F4 and F8 recorders. They appear to have significantly improved performance and build quality compared to the little plastic “shaver” F-series recorders.
    NO, The 3.5mm input is TRS and stereo. It is NOT balanced at all. You can’t do balanced stereo with only 3 conductors (T, R, S) Stereo on any TRS plug is UN-balanced by definition. Always.
    Because the input to the Zoom recorder is unbalanced, then you need UNbalanced, TS plugs at the source (the Roland Tri-Capture).
