Connect to Primary Storyline (Q) in FCPX – in Premier?
Hey all,
Long time lurker, first time poster – thanks to all who have helped me so far – little you knew.
I used the Q hotkey continuously in FCPX – it places the clip from the source monitor above the primary storyline without moving anything else out of place. You could arrange a whole interview and then just smash your cutaways in with Q and then fine edit.
In the case of Premier – I just want to insert the source clip into a track where my sequence line is with a hotkey. E.g:
– Make an interview edit on track 1.
– A bin with all my cutaways in.
– I get a track from here in the source viewer, in out points.
– highlight track 2
– place my sequence line where I was the clip to begin on that track
– smack [THE HOTKEY] and it goes from the source monitor to set point.Please let me know if this is possible.
Cheers.
