Activity Forums Maxon Cinema 4D Connect Shader with Sound Effector?
  • Connect Shader with Sound Effector?
    Posted by Stephen Turcotte on October 19, 2011 at 2:21 pm
    I have an audio meter- a cube connected to a cloner object, which is driven by the sound effector.
    Is there a way to create a custom shader that can work similar to the frequency color within the sound effector?
    My audio bars need reflections/ transparency and this can’t be done within the sound effectors color settings.
    Any ideas?
    Thanks.
    Stephen Turcotte replied 14 years, 6 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    October 19, 2011 at 7:27 pm
    You can put a mograph color shader inside of a colorizer shader — should get you where you want to go.
  • Stephen Turcotte
    October 19, 2011 at 8:21 pm
    Thanks so much, worked like a charm.
