Activity Forums Maxon Cinema 4D connect motext and object
  • connect motext and object
    Posted by Hamid Rohi-bilverdy on March 19, 2014 at 1:19 pm
    Hi.
    I have an object and a motext. When i try to connect them they disssapear from the scene?? Showing only some axsis. I havevtried to make them editable first also. No luck. Apparently if i can make all my models/objects connect act as one object then nitroblast plugin will accept and fracture it. Othervise i get “can’t break this” except if it is just a object like a cube spehere etc..
    Please advice.
    Br HRB
    Hamid Rohi-bilverdy replied 12 years, 6 months ago 2 Members · 2 Replies
  • Brian Jones
    March 19, 2014 at 3:17 pm
    you can’t connect objects unless they are all editable otherwise you just get the empty object you have experienced. It might be the MoText since those need to be made editable more than once. The first one just turns the MoText into a bunch of grouped extrudes – those have to be made editable too before everything will connect.
  • Hamid Rohi-bilverdy
    March 19, 2014 at 4:02 pm
    Thank you sir. Yes that was it. after i made the motext editable then i selected its children and made it editable again, connected and deleted perfectly.
