Activity Forums Adobe After Effects Connect Layers to anchor point generated by Newton then apply a texture
  • Connect Layers to anchor point generated by Newton then apply a texture
    Posted by Scott Green on January 21, 2015 at 2:18 pm
    I want to animate a childs tree swing swinging using Newton, then using the AEscripts Connect Layers script with the ‘Rope’ option to join them. I then want to apply a realistic rope texture to it instead of just a normal stroke line.
    I don’t think this is going to be possible using Layer Styles and I think I might run into problems if I try and use the Puppet Tool to try and apply the texture to the it and make it follow the movement accurately.
    Any other ideas would be a great help.
    Thank you.
    Splurj Creative, Video Production, Motion Graphics & Animation in Manchester UK.
    Scott Green replied 11 years, 6 months ago 3 Members · 5 Replies
  • Michael Szalapski
    January 22, 2015 at 3:34 pm
    What kind of animation are we talking about? If the rope isn’t going to bend, but is just going to be a fairly straight line, this should be pretty easy to do with the puppet pin tool. Just tie a pin to the swing layer’s position with expressions.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Jason Jantzen
    January 22, 2015 at 7:10 pm
    I just used Puppet Pins and animated the swing with some Newton chains (squares attached with joints and the bottom one had a spring joint I think just for fun).
    Or like Michael says, you could simply use some expressions to make it swing about. I like to use the animation tools in the DUIK script, which are free, to create a quick IK chain, then animate the bottom null (connected to the pin, or “bone” with DUIK).
    https://vimeo.com/8141832
    Jason Jantzen
    vimeo.com/jasonj
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Scott Green
    March 3, 2015 at 1:39 pm
    Does anybody know how to move the anchor point of a joint in newton?
    I don’t want my anchor point centered I want it placed more near the top of the object?
  • Jason Jantzen
    March 3, 2015 at 6:18 pm
    The shortcut is Y. It’s the same shortcut for the pan behind tool which consequently is how you move any layer’s anchor point outside of Newton.
    Jason Jantzen
    vimeo.com/jasonj
  • Scott Green
    March 4, 2015 at 12:54 pm
    That’s the one key I didn’t think of, thanks Jason 🙂
