Activity Forums Blackmagic Design connect decklink pro to TV set?
  • connect decklink pro to TV set?
    Posted by Jody Kerr on June 24, 2005 at 9:06 am
    Hi, just installed my decklink pro, havent purchased a broadcast monitor as yet,so would like to connect decklink pro to my tv for monitoring. Can anyone point me in the right direction? Is this possible?
    Thanks in advance!!
    Cheers.
    Andrew Yoole replied 20 years, 10 months ago 4 Members · 4 Replies
  • Olivier Jean
    June 24, 2005 at 2:25 pm
    get a bnc to rca connector and plug it to your
    y video out cable on your decklink , connect to your tv,
    it the win version is the same as the mac, got to your
    BM control Panel, select video output through Y out and
    you should be all setup
    Regards
    Olivier Jean
    Powermedia Systems
    Sydney Australia
  • Andrew Yoole
    June 29, 2005 at 4:10 am
    Sorry Olivier, that’s not correct. The Decklink Pro has no analog output – you cannot connect the Pro to anything unless it has an SDI input. You can purchase SDI-Analog convertors, but frankly I’d be more inclined to replace the card for a Decklink Extreme.
  • Yves De muyter
    June 29, 2005 at 5:37 am
    Euhm, the decklink pro has component YUV output, which you can configure to be a composite output on the “Y” connector.
    The regular decklink is the only SD card that has no analog out.
    -Yves
  • Andrew Yoole
    June 29, 2005 at 5:52 am
    You’re absolutely right, and I am absolutely wrong. Temporary brain collapse from too many light nights… (slinks off sheepishly…)
