Activity › Forums › Adobe After Effects › Connect a Reference monitor to After FX? Possible?
Posted by Daniel Martinez on October 4, 2005 at 6:44 amHi there.
I want to color grade a shortfilm I edited in Adobe Premiere Pro in PAL. And I want to grade it with After FX.
Now I need to connect a Reference monitor to a viedo card with either SDI or Component video signals.How do I output the video from AfterFX to that screen?
Is it possible at all to connect a reference monitor to AfterFX as it can with Adobe Premiere Pro?
Do you know of any issues that I should be aware of in this situaion?
Any other comments?Thanks
Daniel Martinez replied 20 years, 12 months ago 5 Members · 11 Replies -
Damian Dunne
October 4, 2005 at 6:53 amYeah it’s just a matter of going into AE>prefernces>video preview. Then select your device from the drop down menu and bobs your uncle.
D. -
Accountneedsrealnameupdate
October 4, 2005 at 10:58 pmI’d recommend a Blackmagic Design Decklink card, they have SDI models for as little as $295, what are you using with Premiere?
I’ve had trouble with two applications fighting for the external monitor but with a single app open it should work fine.
Glenn Stewart
1K Studios -
Daniel Martinez
October 5, 2005 at 11:33 amOh, I don’t use any specefic video card with premiere yet.
I’m still waiting for my new workstation, and so far I’m just using 2 VGA monitors and having my source preview and project window on one, and my timeline on the other.I heard though that Decklink shouldn’t be that good a choise after all.
The reason he gave me for this, was that Decklink is to unstable. That it would “disapear” from the system and you then would have to reboot. Or at least restart the aplication. Is there anything to this? -
Steve Roberts
October 5, 2005 at 12:17 pmMy Decklink SP works fine. Sometimes, when I’m running FCP and AE, they fight over the display, but closing one app calms them down.
Steve
October 5, 2005 at 6:43 pmI haven’t used the decklink cards on the PC that much, we’re mostly Mac here and they work great. Check out the forum here to see what kind of problems people are having, but remember it’s going to be completely biased towards people with problems. The move to PC is relatively recent for them and I’m sure there have been teething troubles but they’re a great company and enable new features all the time.
As far as price goes they can’t be beat as far as I’m concerned. Just out of interest what other cards have been recommended to you?Glenn Stewart
1k Studios -
Barend Onneweer
October 5, 2005 at 7:38 pmMy Decklink board has performed flawlessly in After Effects. It can be a bit more fiddly with Premiere Pro because it demands a lot more from the system integration and compatibility. But for AE I don’t think there’s any issues with the Decklink series on Windows.
Bar3nd
Forum COWmunity leader for:
ADOBE AFTER EFFECTS
MAGIC BULLET SUITE
INDIE FILM & DOCUMENTARY -
Damian Dunne
October 5, 2005 at 11:25 pmyeah our decklink card works without a hitch as well. The only problems are the ones already listed (when you have Final Cut and AE open at the same time).
D. -
Daniel Martinez
October 6, 2005 at 9:45 pmI forgot to mension that the Decklink issue is a PC related one.
I was told that the decklink card was dessigned towards MAC and that on the PC it should be unstable.All you guys with no problems also mention FCP, and that also spells MAC.
Still, I have no first hand knowledge of this. I was only told.
Cheers.
October 7, 2005 at 2:01 amI still recommend posting to the Decklink forum here and see what they say. As I said before we’re mostly mac but my guess is that they’re pretty stable on the PC when using only after effects, Barend’s post was exactly what I expected to hear and is pretty much what we’ve seen on the Mac. I can’t think of anything specific about the card’s hardware that would make them more stable on the Mac than PC.
Glenn Stewart
1K Studios -
Steve Roberts
October 7, 2005 at 2:13 amIt’s my understanding that the Decklink cards are much more stable on Windows than they used to be, but as Glenn wrote, try posting on the Decklink COW forum for up-to-date info. Also search there for “PC”.
Steve
