Activity › Forums › Blackmagic Design › Congrats to the BMD staff
  • Congrats to the BMD staff
    Posted by Steve Wargo on April 22, 2005 at 10:28 am
    Recently, I was quite outspoken about BMD’s failure to provide a timely response in relation to the shipment of the Multibridge. Well, NAB opens up and what appears? Not one, but three models of the Multibridge. Even though there were problems with the supplier for a part for the Multibridge, the R&D team kept pushing forward with the creation of two expanded models that exceed the specs and limitations of any competing product built by anyone on the planet, or anywhere else for that matter. The standard Multibridge is in the final stages of a microscopic quality control process and should ship any day now. The two larger and very loaded Multibridge Extreme and Multibridge Studio versions will start to ship in July (Extreme) with the Studio version to follow shortly.
    The following is a copy and paste of a note sent out by Grant Petty, probably one of the most hard working, honest guys in the business.
    Special thanks to Matt Dowling, by the way.
    It’s NAB time again, and we have been working hard on new products and
    updates!
    Introducing Multibridge Extreme
    One of our new hardware products for NAB 2005 is called Multibridge
    Extreme. This is very exciting, because we have taken our Multibridge,
    which is a bi-directional converter, and added DVI-D as well as PCI Express
    to it.
    What this creates is a bi-directional converter that’s great for connecting
    analog equipment to SDI in either high definition, or standard definition.
    However when you connect the built in PCI Express connection to a computer,
    it instantly turns into a capture playback device with support for standard
    definition, high definition, dual link 4:4:4 high definition or 2K feature
    film quality.
    The PCI Express connection is high speed at 10 Gbps, so we easily have
    enough speed for the highest quality feature film resolution, while also
    being very low cost because it’s already built into most new PCI
    motherboards. We supply a plug in PCI Express adapter card and 7 foot/2
    meter cable to connect the Multibridge Extreme into the computer’s
    motherboard, and because it’s a direct bus connection there is no latency.
    If you’re using a PowerMac G5, we have also developed a PCI Express Bridge
    that plugs into the G5 PCI-X 133 MHz slot, and has PCI Express on the back
    panel.
    With the built in Dual Link DVI-D connection, we can connect a low cost LCD
    display directly to Multibridge Extreme for local monitoring. This DVI
    connection is dual link, so you can connect larger 30 inch displays, and we
    will use the high speed of PCI Express and the extra resolution of dual
    link DVI to display real time 2K images played back via Multibridge. That
    means we are now actually higher resolution than the HD television system,
    which is cool, but you can also use smaller, single link DVI-D displays.
    I think this is really exciting, and you could use Multibridge simply as an
    independent converter, and if you need an extra editing system, just grab
    it and connect it to a computer. If you don’t need the editing system any
    longer, you can still use it as a converter. Because all the electronics
    are external to the computer, we have plenty of room for connectors.
    Multibridge Extreme has 2 channels of analog audio in and out, component
    video in and out, and composite video in and out. Genlock input, RCA low
    level audio output, DVI-D dual link, RS-422 remote, 8 channels of AES in
    and out, with each input featuring a sample rate converter, dual link SDI
    in and out and USB. Amazingly it all fits into exactly the same size as our
    current Multibridge so that means it’s small enough to hide when space is
    tight.
    Introducing Multibridge Studio
    Multibridge Studio is a larger 2 rack unit version, that has extra
    connections. It has all the connections of the 1 rack unit Multibridge
    Extreme, however has 12 channels of AES audio in and out, 4 extra composite
    video outputs, and 6 RCA audio outputs. It also has a sync generator built
    in, and generates black burst or TriSync output for locking equipment in
    your facility.
    Multibridge Extreme is US$2,595 and Multibridge Studio is US$3,495. We
    expect Multibridge Extreme to ship first, in about a July timeframe.
    We are excited by these new models, and they are really different to just
    plugging in a card. Even though the current Multibridge models have been
    held up with a delay in getting a component for them, our engineers have
    not wasted time while they wait for the components to arrive, and have
    continued to develop Multibridge with models incorporating new ideas.
    Incidentally the current Multibridge models should ship any day now, as we
    received the component we have been waiting for.
    There is a lot more info on our updated web site at
    http://www.blackmagic-design.com. Please check it out.
    Introducing FrameLink
    We have a new software utility we are showing at NAB 2005 that will be
    included free with all DeckLink cards, and it allows DPX file format
    compatibility for Digital Intermediate (DI) feature film work.
    One of the big problems, with using QuickTime and DirectShow compatible
    capture cards for film work, is their use of QuickTime and AVI file
    formats. These files are not compatible with most network rendering
    software, and don’t allow single frames to be opened and saved back into
    the movie, which makes dirt and scratch removal hard. Lots of software use
    the DPX file format, and FrameLink allows DPX compatibility while retaining
    the speed and flexibility of QuickTime and AVI files.
    FrameLink actually mounts a QuickTime or AVI file as a disk volume, and the
    disk volume appears as a numbered image sequence. It’s all handled in real
    time so mounting is instant, and you can immediately open a frame. When you
    save, the frame is written back into the movie, and you can then play the
    file immediately. You don’t need to wait for heaps of DPX files to be
    rendered into a movie as with a file format conversion utility. FrameLink
    does it all in real time.
    So you can just mount the movie file, open a frame in Photoshop, paint it,
    and select save. Instantly play back, and you can see the effects of your
    painted frame inserted right back into the movie file. The movie file can
    even be open in a NLE application and you can work on it and play any time.
    It’s very exciting.
    FrameLink uses frame numbers to work out where frames go in the movie, so
    you can network render and as numbered frames are written into the volume,
    they are automatically ordered in the correct position into the movie. You
    can create empty movies and just render or copy to the volume to build the
    movie. The length of the movie becomes the highest frame count, and as each
    frame is saved, the QuickTime or AVI header is saved so you don’t loose the
    movie file if there is some kind of crash. That’s one of the biggest
    reasons many people like rendering in DPX files, and we get that benefit.
    We had considered writing software to capture and play DPX files, however
    it’s very hard on disk systems, and SAN’s because you need to open 24 files
    per second when doing real time capture, and you cannot edit folders of
    frames very easily in NLE software. Media management is also a mess. This
    method is much better and has the advantage of single file QuickTime and
    AVI files, with the flexibility of DPX whenever you need to work in that
    format.
    FrameLink will be included in DeckLink V5 software for Mac OS X and Windows
    XP. This will be released in a few weeks.
    DeckLink for Macintosh v5
    We have a new version of DeckLink software for full compatibility with the
    wonderful new features in Final Cut Pro 5. We have support for all features
    such as HDV playback via DeckLink, uncompressed HD real time effects, 12
    channels of audio capture and playback in HD, and many more. It’s a
    wonderful update, and it’s also compatible with the upcoming Tiger OS
    release.
    We will include FrameLink with this update as well as a new feature
    allowing HDLink custom gamma tables to be loaded into the capture side of
    DeckLink HD Pro. You can apply custom gamma tables to any captured video,
    and that’s great for feature film work. We have seen a lot of feature film
    work being competed on DeckLink HD cards such as The Aviator, and these
    enhancements will help film workflow dramatically.
    DeckLink for Macintosh v5 will ship when Final Cut Pro v5 is released, and
    will be recommended for use with Final Cut Pro v5.
    DeckLink for Windows
    We have a new DeckLink for Windows update, and this release builds on the
    real time effects we added into the last update. We now have real time
    effects working better in HD, and that really speeds up most HD editing
    work. We will be adding more effects over time as we release more updates.
    Adobe has also just announced that DeckLink is now certified for Premiere
    Pro, and that’s really great news. DeckLink HD Pro is the only solution
    available for editing with Premiere Pro in 4:4:4 RGB 10 bit, so that’s
    really exciting if you’re using Premiere Pro for film editing or other high
    end work.
    Sony Vegas v6 is also supported in this new DeckLink for Windows update,
    and we know a lot of people have been asking for this. Support is mostly
    for standard definition currently, however we expect that to expand. We
    will be showing Sony Vegas on one of our demo stations at NAB playing back
    to DeckLink.
    HDLink v1.7
    We have a new HDLink software update, and this includes default gamma
    tables for Panasonic cameras and Thompson Viper cameras. We have a blue
    only setting, as well as a field emulator to make field movement look a
    little better on progressive LCD displays. This update also has a pulldown
    override mode so you can use monitors that won’t automatically configure
    because they don’t provide correct EDID info. Some Plasma displays and
    projectors suffer from this problem.
    HDLink v1.7 is in final testing now, and should ship within a week or two
    after NAB.
    As you can see this is going to be an exciting NAB for us and if your
    visiting the show, please stop by to see these updates. It’s really
    exciting that after all this development we can finally tell people about
    these new updates! We are located about halfway down the south hall.
    Regards,
    Grant Petty
    Blackmagic Design
    NOTE: We try to keep up updates for when we have something important to
    tell
    you, however if you would like to be excluded from future updates from us,
    please drop us an email at unsubscribe@blackmagic-design.com.
    My friends in Hollywood say that the DPX thing is BIG, real BIG!
    Order yours today.
    Steve Wargo
    HD CineAlta Cinematographer, editor
    Steve Wargo replied 21 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
