Activity Forums Apple Final Cut Pro Legacy Confusion in creating timeline…
  • Confusion in creating timeline…
    Posted by Vineet Das on February 23, 2012 at 5:36 am
    Hi there
    My producer give me footages of various varieties like hd sd which have different frame sizes & captured through various codecs.
    I generally have to create a film from a mixed variety of footages.
    Now the problem is what would we the appropriate timeline for me to work on. (which should not ask me for rendering again & again)
    Pls help
    Vineet
    (Trying to Rise)
    Bret Williams replied 14 years, 7 months ago 3 Members · 2 Replies
  • Andy Mees
    February 23, 2012 at 10:03 am
    To reduce your rendering needs, try to work in the format which best matches the majority of your footage. That said, you’ll almost certainly want to make sure that your choose working format is an native FCP one … and that you turn on “Unlimited RT” in your timeline RT menu (button at top left of timeline).
    Good luck
    Andy
  • Bret Williams
    February 23, 2012 at 6:27 pm
    The proper timeline is simple. What format do they want? HD? SD? 24p? 29.97? If they don’t care then it’s a judgement call on your part. But if you’re using HD footage, I’d work in HD, even if the majority is SD. Unless specifically you know that you will never need an HD output. Clients often ask for an HD copy or a widescreen copy after a SD project is finished.
    If all you care about is rendering, then work in a timeline that matches the majority of your footage. But it needs to be a format supported by FCPs RT presets. For example if your footage is h264, or other distribution formats then you’ll need to convert those to an editing codec like ProRes first.
