Activity › Forums › AJA Video Systems › Confusing problem
Confusing problem
Posted by Don Wilson on June 25, 2007 at 7:20 amHey guys,
All has been well. Working on a feature for quite a while. Have updated to FCp 6 for Color and have opened my feature sequence in new software. All the video is playing fast. Audio and video obviously go out of sync. The timeline does not sync with the audio i.e the timeline scrolls faster than the audio. This is causing me serious grief. Sure hope someone has an answer.
Don Wilson
Michael Sacci replied 19 years, 3 months ago 4 Members · 8 Replies -
Don Wilson
June 25, 2007 at 7:29 amSo I start a new project and import some of my old footage into it and it’s all out of sync and rubbery. Sure wanted to use this new version for color etc.
Don Wilson
David Roth weiss
June 25, 2007 at 4:12 pmDon,
More info needed… What type of footage? Easy Setup? etc, etc, etc…
Did you update your Kona drivers? Did you uninstall the old ones first?
“No job is worth doing more than once…”
David Roth Weiss
Director/Editor/Post-production Supervisor
David Weiss Productions, Inc.
Los Angeles -
Don Wilson
June 25, 2007 at 6:43 pmI appear to have solved this by trashing all things FCP……..i.e. prefs, plist, ..anything I could find related EXCEPT the actual install. I then re-converted my sequence and all is fine. Took hours of problem solving and testing.
I am finding that when I go into the log and transfer for P2 import that it is VERY volitle and crashes more than not. Just finished a big Cine Expo presentation with 10 bit uncompressed HD and had nightmare problems and this was at an Apple beta house.
Love the way FCP edits but it sure is not very robust.
Don Wilson
Don Wilson
AmericanaMediaInc.com
MississippiSon.com -
Walter Biscardi
June 26, 2007 at 11:25 am[msacci] “I’m having real issues with Kona3 and FCP6 on a MacPro.”
Like what? We have two Kona 3 systems running 4 weeks and 2 weeks now with zero issues. Did you install the Kona v4 drivers?
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Walter Biscardi
June 26, 2007 at 11:27 am[Don Wilson] ”
I appear to have solved this by trashing all things FCP……..i.e. prefs, plist, ..anything I could find related EXCEPT the actual install. I then re-converted my sequence and all is fine. Took hours of problem solving and testing.”
That’s a must anytime you install a new version of FCP. Actully all of that should have been removed during the install and certainly when you installed the new Kona v.4 drivers.
[Don Wilson] ”
Love the way FCP edits but it sure is not very robust.”Solid and robust here going on one month on one Kona 3 system and 2 weeks on another Kona 3 system. SD and HD running here along with some huge H.264 files that would have certainly crashed FCP 5.1.4 in the past.
Michael Sacci
June 29, 2007 at 1:17 pmWalter,
Sorry, I posted in other threads but I cannot get multi-cam viewing to work right. 7 DVCPorHD streams plays back about 1-2 frames per second. No matter how the I set the quality settings it doesn’t playback correctly. Also the analog component out doesn’t have the same quality.
I have projects that were started in 5.1.4 so I can reboot to 5.1.4 and multi-cam and monitoring is just fine. Same files, same system.
Michael Sacci
June 29, 2007 at 6:36 pmSeems like 6.0.1 fixed the problem. One down about 24,000 to go!
