Activity › Forums › Adobe Encore DVD › Confused on Photoshop Doc for Encore Menu
  • Confused on Photoshop Doc for Encore Menu
    Posted by Kevin Obrien on February 18, 2013 at 9:43 pm
    I’m working with 1920x1080p HD footage and will be authoring a DVD in Encore. I need to create the Menu Screens in Photoshop from scratch using my own photographs. I’m going to transcode the video to be wide format on the DVD.
    I need to know what Image Dimensions within Photoshop should I use to create the DVD Menus so that they will work in Encore. I’m using Photoshop CS5
    I tried using the “Film & Video” preset in Photoshop which gives an image of 720×480 and 72ppi … and the photo looks like crap.. very pixelated around the edges. Am I doing something wrong?
    Thanks for input…
    Kevin Obrien replied 13 years, 7 months ago 2 Members · 2 Replies
  • Stan Jones
    February 19, 2013 at 3:12 am
    Use a menu from the Encore library, then “edit in Photoshop” and change anything you want to change. Yes it will be 720×480.
    PPI is irrelevant in video. Pixel dimensions and pixel aspect ratio are the relevant variables.
    Stan Jones
  • Kevin Obrien
    February 19, 2013 at 4:27 pm
    Thanks Stan for the reply… So any photo I use will be “stretched” to widescreen… correct? I assume there is no way to minimize this (ie “prep”/edit the image) prior to use in wide format)?
