Activity Forums Compression Techniques Confused on 720×480 and 640×480
  • Confused on 720×480 and 640×480
    Posted by Scott Davis on February 16, 2007 at 8:01 pm
    I am putting together short bits that are shot in DV, edited in DV but distributed via YouTube,iTunes,Brightcove, etc. All require 320×240 (half of 640×480) sizing. Should I use compressor (using h.264 codec) to scale down to 320×240? Does this distort. Do I need to convert to square pixels for internet distribution? AHHHHHH, my head hurts.
    Ben Waggoner replied 19 years, 6 months ago 2 Members · 3 Replies
  • Ben Waggoner
    February 18, 2007 at 7:59 am
    Yes, if your source is 4:3 (no matter the pixel count) you want to deliver as 4:3 square pixel for transcoding from 320×240.
    The simplest thing to do is forget you know how many pixels are in the source – just make sure your source aspect ratio matches your output aspect ratio.
  • Scott Davis
    February 18, 2007 at 9:36 pm
    [Ben Waggoner] “The simplest thing to do is forget you know how many pixels are in the source – just make sure your source aspect ratio matches your output aspect ratio.”
    So in a 720×480 (DV NTSC) project it will distort, no?
  • Ben Waggoner
    February 19, 2007 at 6:32 pm
    It’ll be corrected on the screen, so you shouldn’t have a problem.
