Activity › Forums › Apple Final Cut Pro Legacy › Confused
Confused
Posted by Matt Goodfield on August 25, 2011 at 1:45 amNow Final Cut X has been released what I don’t get is , is this a replacement for the studio
Where are apple going with this
They have also stopped selling the Studio but X cant do half as much can it ?
Can someone explain !
Jerry Hofmann replied 15 years ago 4 Members · 4 Replies -
Jeremy Garchow
August 25, 2011 at 1:49 amHighly recommend heading over to the FCPX forum and start reading. Set aside a couple of weeks to get through the posts.
https://forums.creativecow.net/finalcutprox
Jerry Hofmann
August 25, 2011 at 2:56 amStart about a month ago. Once people started to look past a missing feature set.
Jerry
Michael Gissing
August 25, 2011 at 5:17 amIn a nutshell, FCS is EOL. FCP X is a totally new editing app aimed at non broadcast work and is based on imovie. If you work in broadcast you need to stick with FCS3.
Jerry Hofmann
August 25, 2011 at 12:28 pmIt’s not based on iMovie. It has design cues from it, but the code is completely new.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
