Activity › Forums › Adobe Premiere Pro › Confused
  • Posted by Pete Fair on October 2, 2006 at 1:18 am
    Dear Vincent and Mike,
    Thanks to you both for the helpful info! In any event, I can help to feel a bit confused at the moment by the various aspect ratios you mentioned in your posts: initially 640 x 480, then 1200 x 900 and lastly 720 x 480. Whereas the Premiere Pro preset for uncompressed NTSC indicates 720 x 486? Is there one I should choose over the rest for optimal results? Thank you for your feedback. Regards, Pete
    Vince Becquiot replied 20 years ago 3 Members · 2 Replies
  • Aanarav Sareen
    October 2, 2006 at 1:53 am
    Pete,
    It depends on your output. If you are using the NTSC standard, then select the 720*486 preset.
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Vince Becquiot
    October 2, 2006 at 4:55 am
    Pete,
    Yes, what Aanarav said 😉
    These different formats have to do with the fact that you are transferring images from a computer format to a TV format.
    Square pixels in a computer, rectangular pixels in a TV format. 720×480 is particular to the “DV” format. 720×486 is standard NTSC format. Confused yet (or still ;)?
    I recommended the 1280×960 for the original resolution of your images as an example for zooming in 200% in your pictures so that you wouldn’t lose quality in zooms. If you wanted to zoom in 300%, then I would recommend 1920×1440 (640×480 x 3) for the original pictures, etc.
    Again, I am using the 640×480, because we are taking computer pixel aspect ration.
    Vince
