Activity › Forums › Apple Final Cut Pro Legacy › Confrom 50fps with Cinema Tools
Posted by Sascha Engel on January 10, 2013 at 11:55 amI used to conform my SloMo Material in Cinema Tools.
The source is some AVCHD SloMo 50fps material from my Panasonic TM-900.
With ClipWarp I changed that first to ProRes (LT), now I want to conform it with CT to 25fps.
But it only shows me the analysis window. It does not give me the option to conform.
Any idea why?Thanx.
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikangRahul Kumar replied 9 years, 11 months ago 6 Members · 13 Replies -
Massimo Alberto croce
January 10, 2013 at 3:39 pmOpen cinema tools go to File> Batch Conform, select folder where your clips are, select first clip and click ok will be prompt how to conform clips (24,25 and so on) click ok and boom all of your clips will be conformed
Massimo Alberto Croce
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com -
Sascha Engel
January 10, 2013 at 3:58 pmThat’s the way I did it.
But it put all the clips in the “skipped” folder, saying there was an error.
Any idea why?Sascha Engel
http://www.youtube.com/taikang -
January 10, 2013 at 7:58 pmwhat kind of error? look at the info in QT player on the original file and tell me what you read…
In anyway try trashing pref on cinema tools and restart.Massimo Alberto Croce
Sascha Engel
January 10, 2013 at 8:08 pmWell, one Q I anyway have on top of the other ones – since I am not often Tools often: When I open The App, it asks me to create a new data base or open an existing. I know, chose create a new database, simply to the default location it offers.
So, then I do Batch conform, it renders for 2 sec. Then it created a conform.log file, a conformed 25.0 Folder (which is empty) and a “skipped” Folder where all the clips are in, still playing back at normal speed at 50fps.
Sascha Engel
Sascha Engel
January 10, 2013 at 8:09 pmthe confrom log said following:
Begin Jan 10, 2013 10:06:55 PM
Conform 00032.mov 10:06:55 PM
Skipped — The movie has temporal compression 00032.mov
Conform 00033.mov 10:06:55 PM
Skipped — The movie has temporal compression 00033.mov
Conform 00042.mov 10:06:56 PM
Skipped — The movie has temporal compression 00042.mov
Conform 00044.mov 10:06:56 PM
Skipped — The movie has temporal compression 00044.mov
Done Jan 10, 2013 10:06:56 PM -
January 10, 2013 at 10:25 pmi think there is something wrong in the conversion from camera to prores.
try to convert using Compressor if you can do this with it (i never worked Panasonic with) o try another codec. Make a test with one clip
I do a conforming 3 days ago from 30 to 25fps with cinema tools from a canon 5d files converted to prores with no problem.tMassimo Alberto Croce
Sascha Engel
January 10, 2013 at 10:40 pmClipwrap is the only software – at least that I own, that unwraps and transcodes AVCHD files, which are .MTS files – they are not recognized by compressor, neither by Grinder.
So, Clipwrap is the only option, and it does a very reliable job actually. I analysed the files also in AE and they are uncorrupted and ok.Sascha Engel
Misha Aranyshev
January 10, 2013 at 11:12 pmCinemaTools tells you that the files have interframe compression. ProRes is intraframe codec. So your files are probably rewrapped but not converted to ProRes.
Sascha Engel
January 10, 2013 at 11:41 pmWeird. It says it’s prores LT in AE. I will try to run it again through ClipWrap.
Thanx.Sascha Engel
Facundo Jacinto
March 22, 2013 at 4:15 pmHi there!
Im Having the same problem as Sascha!
Any solution there?
Thanks a lot!
