Activity › Forums › Apple Final Cut Pro › Confounded as to how to change Project Name
  • Confounded as to how to change Project Name
    Posted by Lance Moody on November 11, 2011 at 3:16 pm
    Just wondering if anyone else is seeing this behavior:
    I know that changing the project name is supposed to be as simple as clicking on the name in the project library and then typing.
    But for me this often doesn’t work. Sometimes clicking on the name doesn’t cause the text to become active and changeable,
    To increase the annoyance, later I might come back to the project library and clicking to change works fine.
    Anyone else seeing this?
    Lance
    Tom Wolsky replied 14 years, 10 months ago 7 Members · 10 Replies
  • 10 Replies
  • Oliver Peters
    November 11, 2011 at 3:32 pm
    Not in front of the machine, so I’m going from memory. Select the project in the project browser. Open the inspector window to view the project properties. Click on the wrench/tool icon, which should then let you change properties, including the name.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Lance Moody
    November 11, 2011 at 3:48 pm
    Thanks Oliver!
    This is a working alternative to the official method.
    I’m still wondering if others are seeing the same unreliable results using the click and change method.
    Best,
    Lance
  • Tom Wolsky
    November 11, 2011 at 3:51 pm
    Actually no. With the project highlighted in the Project Library, I simply click the name once and the name is selected and the text box is active.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2011 “Complete Training for FCPX” from Class on Demand
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • Oliver Peters
    November 11, 2011 at 4:02 pm
    [Tom Wolsky] “I simply click the name once and the name is selected and the text box is active.”
    I’ve had trouble with that method, as well. May be an intermittent issue.
    – Oliver
    Orlando, FL
  • Nick Toth
    November 11, 2011 at 4:10 pm
    I see this. Notified Apple about it.
  • Matthew Celia
    November 11, 2011 at 8:37 pm
    Often, it won’t work if any background tasks are running. For example, if you duplicated the project and included render files, you have to wait for the project to finish copying all the data.
    FCP Guru
    http://www.fcpguru.com
  • Simon Ubsdell
    November 11, 2011 at 9:42 pm
    I have had this problem a lot this week – intermittent and clearly related to FCPX running out of RAM as it seems to like to do …
    Simon Ubsdell
    Director/Editor/Writer
    http://www.tokyo-uk.com
  • Andy Borowa
    November 12, 2011 at 8:55 am
    You must wait till bacground process will stop
    Pozdro
    Andy
  • Lance Moody
    November 13, 2011 at 1:54 am
    Yes, this may well be the answer. And it’s kinda damning. I have noticed that despite the much ballyhooed new 64-bit engine, that the app can be quite sluggish when renders (or background tasks) are cued up, even on the best equipment with plenty of RAM.
    This is an example of a function that just doesn’t work when it should and it is rather embarrassing. After all, I think I may be MOST likely to rename a project immediately after duplicating. This is plain old terrible UI.
    Lance
  • Tom Wolsky
    November 13, 2011 at 2:16 am
    When you rename a project you’re renaming a folder on the hard drive. If any function is occurring into that folder you cannot change the name. You cannot do it at the finder level; you can’t do within the app.
    All the best,
    Tom
