Activity › Forums › Sony Cameras › Conforming XD CAM HD edit to tape
  • Conforming XD CAM HD edit to tape
    Posted by Bob on November 15, 2006 at 11:04 pm
    We running FCP 5.1.2 and editing on an XDCAm 25 CBR timeline, we’re wondering if we have it set correctly becuase the conforming times are huge. Will this be worse with the 35VBR setting? Is there something we can do to streamline this.
    We have Kona 2 cards but love the fact that we can use the transfer software and not digitize for days. But on the back end when we’re always in a hurry the conforming is brutal.
    We havn’t tried putting it back to disk yet via our Sony F30 but I’m guessing the conforming still needs to be done
    Any info or short cuts would be greatly appreciated!
    thanks
    Bob
    FCP 5.1.2, G5 Dual 2.0 4 gb ram
    Bob replied 19 years, 10 months ago 4 Members · 6 Replies
  • Nate Weaver
    November 16, 2006 at 3:54 am
    The “conform” process has to happen if you’re writing an MPEG stream back to an MPEG device. That’s HDV tape or XDCAM disc.
    If you need to layoff to HDCAM, Digibeta, BetaSP, etc, then all you do is “Edit To Tape”. That’s just a render, then.
    New website, new work online:
    https://www.nateweaver.net
  • Bob
    November 16, 2006 at 4:44 am
    So just select edit to tape or render the timeline prior to selecting it, we tried the render to tape and seems like it still goes thru the conform process
    Thanks we’ll try it again
    Bob
  • Nate Weaver
    November 16, 2006 at 6:59 am
    The question is, what tape format you laying off to?
  • Alan Lacey
    November 16, 2006 at 8:10 am
    So exactly what is the difference between ‘conform’ and ‘render’ is it just that an mpeg stream is involved?
    Alan
  • Gareth Sylvester-bradley
    November 16, 2006 at 9:37 am
    Yes, FCP still needs to conform the edits, which takes some time, but FCP shouldn’t have to render the whole sequence.
    Best to upgrade to XDCAM Transfer Version 1.1 though if you haven’t done already, as it is faster all round, including for export.
  • Bob
    November 16, 2006 at 3:57 pm
    We’re on 1.1 XDCAM xfer software, that’s interesting I didn’t realize the xfer software would have to do with the conforming issue.
    Nate to answer your question, one version needs to go to tape thru the Kona 2 card, downconverted to SD letterbox onto a digibeta, another version (HD. XD cam native) is going back to the XD cam HD deck, the F 30 via firewire in FAM mode.
    Is the settings that are making the Kona 2 display video to a monitor and allowing us to go back to tape effecting the conform issue?
    Thanks for your help
    Bob
