Activity Forums Apple Final Cut Pro Legacy Conforming sequence to clip issue
  • Conforming sequence to clip issue
    Posted by David Reichelt on June 28, 2011 at 7:07 am
    I’m having slight problem and am not sure what I am missing. I want to be able to drag a clip into my sequence and have the sequence conform to the clip settings so no rendering is needed. I went to user prefs>editing tab and made sure to have it ask me whether or not to do this when a clip is brought in. However, no pop up comes up and the clip shows that it needs rendering. Can someone please tell me what I’m missing? I have FCP 6 by the way. Thank you.
    Chris Tompkins replied 15 years, 2 months ago 4 Members · 3 Replies
  • Adam Taylor
    June 28, 2011 at 9:08 am
    what format is the file you want to use?
    Its possible the file is one that cannot be used in realtime and will need rendering regardless of the timeline setting.
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    My YouTube Animations Page
  • Alexander Kallas
    June 28, 2011 at 12:55 pm
    With the first clip you pull into the time-line, FCP will offer to match the sequence settings. This will lock that sequence to those settings. Any subsequent addition that does not have the same specs will cause the render bar to appear.
    Cheers
    Alexander
  • Chris Tompkins
    June 28, 2011 at 3:19 pm
    Not true. Deleter ALL clips from the sequence and THEN drag a clip in and u’ll get the mess. again.
    Chris Tompkins
    Video Atlanta LLC
