Activity Forums DSLR Video Conforming Question
  • Conforming Question
    Posted by Joe Mckinney on December 29, 2010 at 4:02 am
    Hey guys, I’ve just been delivered content from three DSLRs to edit. I have two different sizes, two compression settings, and three different frame rates. I’m looking for the best approach to get these files to play well together in a sequence. The info for the files is below. Absolutely any help you guys can give me is appreciated! Thanks!
    7D
    29.97
    1920×1080
    H.264
    D7000
    23.98
    1920×1080
    H.264
    D90
    24
    1280×720
    Apple OpenDML JPEG
    Joe McKinney
    Anthony Bari jr. replied 15 years, 8 months ago 5 Members · 8 Replies
  • 8 Replies
  • Richard Harrington
    December 29, 2010 at 4:09 am
    Edit in PP CS5 natively
    Richard M. Harrington, PMP
    Author: From Still to Motion, Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and Motion Graphics with Adobe Creative Suite 5 Studio Techniques
  • Shane Ross
    December 29, 2010 at 5:38 am
    Which edit system Joe?
    And Richard, does Adobe CS5 mix frame rates well? Properly?
    Shane
    December 29, 2010 at 2:41 pm
    Yes… it does it quite well… using same sort of tech as in AE on final render to blend frames as needed.
    Personally… I’d go 24 as most of his stuff is that and its easier to go down then up
  • Steve Crow
    December 29, 2010 at 3:08 pm
    If using final cut, it’s easy. Just drag your 720p video into the timeline, final cut will ask you if you want to set up a sequence according to this clip’s properties, click on yes.
    Then drag the rest of the clips onto the timeline and they will be automatically conformed to all match the 720p sequence settings. You will have to render but that’s okay.
    Perhaps in Premiere Pro you don’t have to render, I’m not 100% sure on that.
  • Joe Mckinney
    December 30, 2010 at 11:44 pm
    Shane,
    I’m using FCP currently. Thanks for the input!
  • Joe Mckinney
    December 30, 2010 at 11:47 pm
    Thanks for your help Steve. I can’t seem to get the D90 footage to prompt me to set up my sequence. Perhaps it uses a codec that FCP doesn’t recognize?
  • Steve Crow
    December 30, 2010 at 11:52 pm
    Did you set up a new project in FCP?
  • Anthony Bari jr.
    January 4, 2011 at 3:39 am
    Stick to FCP unless you have a high end machine. The Native H.264 is a new feature and still requires
    top notch Graphics Card. If you are on a laptop, transcode to ProRes and you will have alot easier edit.
    I agree with Rich, Premier Pro CS5 is great to edit native H.264, but you should work with what you have.
    *Production*Post-Production*
    Apple Certified Instructor (Final Cut Pro 7)
    “Semper Fi USMC”
