Activity › Forums › Apple Final Cut Pro Legacy › Conforming HDV Message
  • Jamie Allan
    February 5, 2009 at 12:25 pm
    Turn off Full render in your sequence menu, you should only need to conform when you’re printing back to tape.
    Search is your friend:
    https://forums.creativecow.net/thread/8/992125
    https://discussions.apple.com/thread.jspa?threadID=1450369
    Jigsaw Systems Ltd. – IT & Broadcast specialists for the UK
    https://www.jigsaw24.com
    https://www.jigsawbroadcast.com
  • Jerry Hofmann
    February 5, 2009 at 1:14 pm
    I’d think if it’s native HDV it STILL has to conform it.
    Better to capture AS prores and edit that way IMHO…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Mike Johnson
    February 5, 2009 at 2:34 pm
    Rick,
    I run into the same thing every so often. Not sure what causes it. When your render codec is set to ProRes, you shouldn’t have to conform, regardless of what you have selected in the render options. The first time this happened I went to my sequence render control settings and it was still set to ProRes. I clicked OK to get out of the settings window, and tried rendering again. My entire sequence rendered without conforming. I’ve had this problem a number of times since then, and the same thing works. Its odd I know. Almost like FCP needs to be reminded that it should be rendering to ProRes instead of HDV.
    Mike Johnson
    Final Cut Pro Editor
    Drury Outdoors
    http://www.druryoutdoors.com
    View Mike Johnson's profile on LinkedIn
