Activity › Forums › Adobe Premiere Pro › conforming audio from PD150 in PPro 2
  • conforming audio from PD150 in PPro 2
    Posted by Brett Nelson on May 26, 2006 at 8:07 pm
    Has anyone had problems capturing footage shot on a Sony PD150 into PPro 2? I capture footage shot on a PD150 into PPro 2…it captures fine, but it will not conform the audio. I capture footage shot on a Canon XL1 (in both cases using a Sony DSR30 as the capture deck) into the same project and it captures and conforms fine. What’s really weird is I don’t think I had this problem with the same PD150 footage, same project, same source deck when I was using PPro 1.5.
    Can anyone confirm that it’s just my isolated insanity? I started a thread a couple days ago about reconforming audio. But I started this new thread, because it’s not the problem I first thought.
    Brett
    Brett Nelson replied 20 years, 4 months ago 2 Members · 6 Replies
  • Aanarav Sareen
    May 27, 2006 at 8:00 am
    Premiere Pro 2.0 no longer conforms depending on the type of footage you are capturing. What are your project settings and the audio settings of the PD150?
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Brett Nelson
    May 27, 2006 at 10:44 am
    But it’s not conforming audio with footage shot on this camera at all, whether capturing or recapturing. When I capture any footage from any other camera, it conforms audio after capture. Why is it different with this footage? Also why do I have sluggish performance? I don’t have this performance problem when using footage from another source.
    Brett
  • Aanarav Sareen
    May 27, 2006 at 7:31 pm
    Hmm..What are your shooting properties? What is the audio rate?
    Aanarav Sareen
  • Brett Nelson
    May 27, 2006 at 8:13 pm
    16-bit, 48k, video is 29.97 miniDV. The audio sounds clean and consistent throughout 14 hours of footage.
    I am fairly sure that audio conformed with no problem using the same footage in PPro 1.5, because I have a conformed audio file from this same footage and project that I captured before I upgraded. I’ve also tried capturing and recapturing footage from this camera in a completely new project with the same lack of audio conforming.
    thanks!
    Brett
  • Aanarav Sareen
    May 29, 2006 at 7:12 pm
    Brett,
    Premiere Pro 2.0 no longer conforms audio. Can you hear the audio OK when you are playing it within Premiere Pro?
    Aanarav Sareen
  • Brett Nelson
    May 30, 2006 at 1:39 am
    Thanks for your response!
    [Aanarav Sareen] ”
    Steven mentioned previously that 2.0 conforms audio, but only as needed. When I look at clips captured with XL1 footage, each one has a .cfa file. But none of the 14 tapes I shot with the PD150 have generated .cfa’s.
    I do hear audio, which sounds clean, but performance is very sluggish.
    Brett
