Activity Forums Adobe Premiere Pro “conforming audio files” — why?
  • “conforming audio files” — why?
    Posted by Jeff Nelson on May 12, 2005 at 9:24 pm
    Have never seen this in 6.5, but when I import files into a project, it sits there “conforming audio files” for a while. Then I see that it’s created around 4 gigs of audio files on the same drive?
    What’s up here? The raw avi’s are 16 bit 2 chanel “front-center” 48000 sample rate, but for some reason Pro wants to change them to something else, taking time and space.
    Any way to make it work with the sound in the avi file itself, like 6.5 does?
    Thanks.
    Jeff Nelson replied 21 years, 4 months ago 2 Members · 2 Replies
  • Steven L. gotz
    May 12, 2005 at 11:00 pm
    No.
    The advantage to conforming is that Premiere Pro does not have to take the time to separate the audio and the video while trying to play it back in realtime. And it also allows you to edit audio at the sample level instead of at the frame level. And the edits are cleaner at 32 bit than they would be at 16 bit.
    There is no way to turn off conforming in Premiere Pro 1.x
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Jeff Nelson
    May 13, 2005 at 12:29 am
    Thank you. I thought maybe there was a way to change my Pro settings so they would be the same as what’s on my captured avi, but I see there are some advantages. It’s not a major thing in any event.
