Activity › Forums › Apple Final Cut Pro Legacy › Conforming 60fps from T2i in Cinema Tools for Slow Motion
  • Conforming 60fps from T2i in Cinema Tools for Slow Motion
    Posted by Zack Mulvaney on March 4, 2012 at 2:39 am
    From what I understand, the T2i shoots 60fps actually at 59.64. Accordingly, when I conform in cinema tools for slow motion, should I conform to 30 fps and 24 fps? Or should I conform to 29.97 fps and 23.97 fps?
    Zack Mulvaney replied 14 years, 6 months ago 4 Members · 5 Replies
  • Michael Gissing
    March 4, 2012 at 3:12 am
    You should conform to match the sequence you are editing in so no rendering and silky smooth slo mo.
  • Jason Brown
    March 4, 2012 at 3:21 am
    FYI, I do this alot and found fcpx natively in timeline can conform 60 to 30 in real slowmo…it’s not keyframeable (yet) but a step in a good direction.
  • Zack Mulvaney
    March 4, 2012 at 3:24 am
    so let’s say my sequence is set for 23.97 because the rest of my recordings are 24fps from my T2i (which would be 23.97). Then I should conform all my 60fps to 23.97?
  • Jeff Meyer
    March 4, 2012 at 5:44 am
    Yup. As stated before, conform the footage to match the rate you’re editing. If you shot everything else at 23.976 then conform your 59.94 to 23.976. You might make a duplicate copy of your clip before conforming, because it isn’t a reversible process.
  • Zack Mulvaney
    March 4, 2012 at 6:10 am
    Excellent. Thanks for the clarification, all.
