Activity Forums Apple Final Cut Pro Legacy Conforming 24fps to 25fps
  • Conforming 24fps to 25fps
    Posted by Michael Freedman on March 21, 2011 at 10:00 am
    Hello everyone,
    I edited a short film which was shot on 35mm and edited at 24fps. It was then graded at 24fps and I have received the master as a Quicktime at 24fps. I need to now put the film onto a DVD which will be played on UK TV’s at 25fps. Can anyone tell me what the process is to get the film from 24fps to 25fps? What software to use?
    Many thanks for all your help,
    Michael, London, UK.
    Michael F
    Michael Freedman replied 15 years, 6 months ago 5 Members · 6 Replies
  • Tom Wolsky
    March 21, 2011 at 11:12 am
    Normally DVD players will play back 24fps. The adjustment is done on output. If you really want to do it you can try using Cinema Tools to conform it. You’ll have to adjust the audio speed as well, which you can do in Soundtrack Pro.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Neil Sadwelkar
    March 21, 2011 at 12:24 pm
    You have to have a PAL DVD, so you need your program to be at 25 fps.
    You can export your finished timeline as a QuickTime self-contained movie with audio, which will be naturally 24fps. This can be conformed to 25 fps in CinemaTools where even the audio will be adjusted for length. Or course the audio will run 4% faster and hence slightly lifted in pitch too. If there’s music it’s tempo will be 4% faster.
    You can take the 24 fps audio separately to Soundtrack pro and adjust it to 4% faster without any pitch shift. But the tempo of music will be 4% fast and that’s unavoidable.
    24fps movies have always been made to PAL DVDs this way.
    In the NTSC world, they treat the 24fps original film source as 23.976 fps and then add 6 frames to make up 29.97 fps NTSC video with no change in audio tempo (but a minuscule 0.1% speed decrease which is not noticeable).
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Bouke Vahl
    March 21, 2011 at 1:51 pm
    Neil,
    The NTSC route is not quite as you describe.
    (For the OP as well), you need to slow down to 23.976, and make an MpegII from that.
    Imported assets in the authoring package (i suspect DVD SP) now will show the asset if it was 29.97
    The player will add the pulldown (6 extra frames) if needed.
    The 24 to 25 routine is indeed a very common way, but there is no real need to go to 25, as over here about 99% of the players will play NTSC / 23.976 discs just fine.
    (I’ve did a very large project with 25 fps scanned film, intended for international sale. I worked the other way around, slowed down 25 to 23.976, scaled to 720 x 480 to avoid double authoring / mastering / warehouse costs)
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Rafael Amador
    March 21, 2011 at 7:18 pm
    Yeah.
    All Hollywood films are released in all around the World as NTSC DVDs.
    No problems in PAL land.
    rafael
    http://www.nagavideo.com
  • Neil Sadwelkar
    March 22, 2011 at 3:59 am
    Bouke and Rafael,
    I’m aware that DVD Players in most parts of the world, even PAL countries can play NTSC. But the original poster asked how to convert a 24fps source to 25 fps, since he wanted a PAL DVD.
    Here in India too, all our 24fps movies get made into NTSC DVDs for worlwide sales, even in the UK. Very rarely, we get some EU customers who demand true PAL (25fps) DVDs. In that case I use the method I described. The sound team supply me the 25fps pitch corrected sound.
    The tempo variation I described is a real issue as our films have songs and dances that look visibly faster in tempo.
    For NTSC DVDs from 24fps, I usually simply use Compressor to convert 24 to NTSC and it does just fine. I only run into some trouble doing the timecode translation in the subtitle STL, but my friend Kiel has sorted that out, and I too have some Excel scripts to handle that conversion.
    Neil Sadwelkar
    twitter: fcpguru
    Mumbai India
  • Michael Freedman
    March 22, 2011 at 2:13 pm
    Just wanted to say thanks for all the advice. I conformed the QT to 25fps using cinema tools and then did a time stretch in Soundtrack pro without any pitch difference. You can hardly tell the difference.
    Many thanks!
    Michael F
