Activity Forums Apple Final Cut Pro Legacy Conform ProRes file to QT file
  • Conform ProRes file to QT file
    Posted by Michael Prescott on August 19, 2010 at 9:06 pm
    I am recutting a fully mastered show which is to be authored on SD-DVD. The show was previously transferred to BetacamSP and, from that tape, a QT file was created with window-burn TC (see specs below). I only have the QT-window burn file at this point. A higher quality ProRes 422 file (without WB) will be delivered at a later date.
    My question is: if I do an offline edit using the low-rez QT file, will I be able to re-ingest/conform it to the ProRes file using Media Manager?
    The video specs for the QT file are as follows:
    General
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 2.62 GiB
    Duration : 2h 25mn
    Overall bit rate : 2 587 Kbps
    Encoded date : UTC 2009-01-18 20:05:33
    Tagged date : UTC 2009-01-18 20:08:41
    Writing library : Apple QuickTime
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L2.0
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 2h 25mn
    Bit rate mode : Variable
    Bit rate : 1 048 Kbps
    Width : 300 pixels
    Height : 240 pixels
    Display aspect ratio : 5:4
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.582
    Stream size : 1.06 GiB (41%)
    Language : English
    Encoded date : UTC 2009-01-18 20:00:14
    Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Joey Burnham replied 16 years, 1 month ago 4 Members · 5 Replies
  • Walter Biscardi
    August 19, 2010 at 9:49 pm
    Not unless the QT file has proper timecode. No, I don’t believe you’ll be able to conform it to the ProRes capture.
    You’ll have to manually re-cut the project.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” featuring Sigourney Weaver coming soon.
    Blog Twitter Facebook
  • John Fishback
    August 19, 2010 at 10:15 pm
    If your QT doesn’t have embedded timecode you might be able to use Bouke Vahl’s free app to add or set the file’s timecode to match the burned code. If your ProRes file to come has the same code you might be able to reconnect successfully. Maybe Bouke will see this thread and chime in, or you can contact him thru his site.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Michael Prescott
    August 20, 2010 at 1:22 pm
    Someone suggested this work-around:
    Open the clip in the Viewer
    Modify Tab click Timecode
    Add Aux TC 1
    Export QT Movie
    I just tried this and opened the new file in Quicktime and, indeed, there was now an Aux TC (which matches the window-burn TC).
    Will this allow me to now conform the higher resolution file to my offline edit?
  • Michael Prescott
    August 20, 2010 at 4:14 pm
    Follow up to my previous post:
    I changed the “source TC”, not Aux TC.
    However, another problem is that, while the source TC in the browser now reflects the modified TC, the Timeline TC starts at 1:00:00:00 and I can’t get it to show the new source TC.
  • Joey Burnham
    August 20, 2010 at 6:25 pm
    All the above could work but depending on the length of your cut I usually find it easier to online manually by eye. Once you online by media managing / reconnecting media, you have to go through and watch VERY carefully all the mistakes that are bound to crop up. Usually I can overcut faster knowing I’m making the correct cuts rather than leaving it to chance and then fixing all the mistakes.
    Best,
    Joey
