Activity Forums Adobe Audition Conform projects like in Soundtrack Pro?
  • Conform projects like in Soundtrack Pro?
    Posted by Adam Ashby on October 19, 2011 at 12:54 am
    Is there a similar feature to ‘Conform Projects’ in Soundtrack Pro in Audition, or a way to get to the same result?
    In FCP, if you made an edit that affected your audio after you had already sent it to STP, you would send the sequence again, which would make another STP project. Then, in STP you could ‘conform’ that project to the original one sent earlier, which resulted in an new audio project with your original mix updated with your new edits.
    is there a similar work flow in Adobe Production Suite?
    Adam Ashby replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
