Activity Forums Apple Final Cut Pro Legacy Conform Option Not Clickable When Trying to Conform 24p to PAL (25p) in Cinema Tools
  • Conform Option Not Clickable When Trying to Conform 24p to PAL (25p) in Cinema Tools
    Posted by Geoff Hug on February 20, 2011 at 4:35 pm
    I shot a half day’s worth of footage on HVX200 at 720pN, 24p for a client who’s requesting the footage converted to PAL. When I import each clip or a FCP Render of all of them into Cinema Tools, the Conform option is not available in the Clip menu, only the Analysis option.
    I’ve done this conversion several times before with the same settings and never had a problem…any thoughts on what it could be?
    Is it worth trying to do it in Compressor? I’m currently rendering a PAL version of a 3 minute clip which looks like it will take a couple hours and I shot almost two hours of footage.
    Thanks for your help.
    John Pale replied 15 years, 7 months ago 2 Members · 3 Replies
  • John Pale
    February 20, 2011 at 4:46 pm
    Is this HDV? You can’t conform long GOP footage. You need to convert to an iFrame format like ProRes first.
  • Geoff Hug
    February 20, 2011 at 4:49 pm
    It’s DVCProHD 720p60.
  • John Pale
    February 20, 2011 at 5:40 pm
    Have you tried reverse telecine instead?
