Activity Forums Apple Final Cut Pro Legacy Conform from FCP EDL, workflow
  • Conform from FCP EDL, workflow
    Posted by Nancy Kiang on November 4, 2009 at 4:04 pm
    Hello, I am posting this to both the FCP and Avid forums, because I think this question is relevant to after editing is done, and the final conform is done at the post-production house, so it should not matter if the editing was done in FCP or Avid, since one provides just the EDL to the post place.
    I edited a short film on FCP, original film footage that was transferred to digital for off-lining. The original film footage was also saved on tape to BetaSP and DVCAM. The external hard drive that contained all my log-and-capture clips and the FCP project was recently stolen, and I did not have a backup. However, I do have a backup copy of the EDL. I’d like to know if I can take the EDL and original raw footage (either film or the tape copies) to a post-production house to do the conform. This is what I originally remember doing, except I can’t remember how they also loaded the music. I don’t want to have to go through the process of logging and capturing again if I can help it.
    This work was done back in 2005, so the post house probably has not saved the conform data. It looks like I saved both A mode and C mode versions of the EDL.
    Is there any way to re-create my logged and captured clips from the EDL? Thanks for any help.
    Shane Ross replied 16 years, 10 months ago 2 Members · 1 Reply
  • Shane Ross
    November 4, 2009 at 5:39 pm
    The only thing the EDL will be able to do is capture the footage used in the cut. All the rest of the footage, and the bin structure…it won’t be able to do a thing about. And if you had anything like special transitions or plugins that are beyond dissolves or fades, then those won’t transfer. Music…since that lacks any REEL information, and is only imported…that cannot be conformed to the cut, AFAIK.
    Import the EDL into FCP and then recapture the cut. That at least is a start.
    Shane
