Activity › Forums › Apple Final Cut Pro Legacy › Conform frame rate without Cinema Tools?
  • Conform frame rate without Cinema Tools?
    Posted by Clara Rolls on November 11, 2010 at 1:04 pm
    I have some videos captured from an NTSC dvd that I changed to 25fps via Compressor. Quicktime says it’s 25fps but Final Cut 6 is reading it as 29.97 still. For some reason I don’t have Cinema Tools, probably opted out of installing because I’ve never used it 🙁
    CT could fix it so easily but I’m in need of an alternative solution…advice or directions to the right thread much appreciated.
    Cheers 🙂
    Clara Rolls replied 15 years, 10 months ago 2 Members · 2 Replies
  • Walter Soyka
    November 11, 2010 at 4:48 pm
    [Clara Rolls] “I have some videos captured from an NTSC dvd that I changed to 25fps via Compressor. Quicktime says it’s 25fps but Final Cut 6 is reading it as 29.97 still.”
    That’s really bizarre — are you sure Quicktime and FCP are looking at the same files?
    [Clara Rolls] “For some reason I don’t have Cinema Tools, probably opted out of installing because I’ve never used it 🙁 CT could fix it so easily but I’m in need of an alternative solution…advice or directions to the right thread much appreciated.”
    I didn’t realize that Cinema Tools was an optional install. Why not re-run the FCS installer from the original discs and de-select everything but Cinema Tools?
    Walter Soyka
  • Clara Rolls
    November 11, 2010 at 9:50 pm
    Thanks for the response Walter 🙂
    It’s definitely the same file, I’ve triple checked that and tried taking them out of FCP, restarting, putting them back in etc. I read that it’s a common problem when a video is changed from ntsc to pal that FCP misinterprets the metadata.
    I’m afraid I don’t have the installation discs – it was a volume licence from my last job. But if there’s no other solution, I guess I’ll have to find me some discs!
