Activity Forums DaVinci Resolve Conform Check using Quicktime
  • Conform Check using Quicktime
    Posted by Jason Mckee on March 11, 2014 at 6:04 pm
    So I’ve successfully conformed my Avid sequence back to the original R3D files and I wanted to do a Conform Check by bringing in the reference QuickTime and editing it into the video track above my conformed R3D Media. Once my QuickTime is cut in I then tried to re-size the QuickTime to make it smaller and move it down and out of the way so I could see my R3D Media below it. I’ve had sucess doing this once before but now all I get is black below my re-sized QuickTime. I’m new to re-sizing in Resolve so it’s most likely something I’m doing wrong. Also, is there a way to grab the box and re-size in the Sizing pane or do I have to use the sliders. I’ve been re-sizing using “Input Sizing” but I’ve also tried all the other options. Any help is greatly appreciated. Thanks.
    Eric Johnson replied 12 years, 6 months ago 5 Members · 5 Replies
  • Jordan Mena
    March 11, 2014 at 10:22 pm
    Why don’t you just us the link offline option. Page 307 of the manual.
    Jordan Mena | Editor | Colorist | Producer
    Los Angeles, CA
    jordanmena.com
  • Jason Mckee
    March 11, 2014 at 11:55 pm
    I could do it that way but that doesn’t really answer my question. Disregard the Conform. Why would any clip on a video layer above another when scaled down not reveal the video layer or track below it? I’ve done it in the past and it worked but I havent done anything different this time around as far as I can tell.
  • Juan Salvo
    March 12, 2014 at 2:37 am
    Probably edit sizing vs input sizing.
    https://JuanSalvo.com
    https://theColourSpace.com
  • Danny Thompson
    March 12, 2014 at 8:07 pm
    Better yet use the “difference” composite mode to compare them. makes finding slippage problems much easier.
  • Eric Johnson
    March 14, 2014 at 12:32 am
    Pretty sure you need to add an alpha output to the top qt track…
    eric b johnson
    online editor | colorist | workflow
    https://vimeo.com/ebjohnson/colorreel
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
