Activity Forums DaVinci Resolve Conform Alexa 444 project in Final Cut
  • Conform Alexa 444 project in Final Cut
    Posted by Mats Andersen on April 11, 2013 at 5:16 pm
    Working on this feature that for a number of reasons is most
    convenient to online/conform using Final Cut Pro.
    Raw footage is Prores 444, will export xml to get to Resolve.
    Need to retime some of the footage, double the speed.
    Is this safe to do in FCP ?
    Can I be sure that I dont generate new frames if I adjust to 200% in FCP
    and switch off frame blending before I send to Resolve ?
    Mats Andersen replied 13 years, 4 months ago 3 Members · 3 Replies
  • Juan Salvo
    April 14, 2013 at 11:18 pm
    Best is to remove speed effects and then recreate after grading. With the latest versions, speeds usually come across correctly, but not always.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Margus Voll
    April 15, 2013 at 6:01 am
    And you do not get speed changes just linear speed adjust.
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 9, OSX 10.7.4
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • Mats Andersen
    April 15, 2013 at 8:12 pm
    Ok, my solution was to export aaf files from Avid (with some speed adjust settings),
    and then edit the change speed property in Resolve to something that can be
    divided by my framerate (25 fps).
    Does this make sense ?
