Activity Forums Avid Media Composer Conform 60i AMA clips into 23.98 project
  • Conform 60i AMA clips into 23.98 project
    Posted by Mike Jeffs on March 19, 2012 at 11:06 pm
    Currently I have a 23.98 project with AMA linked clips, some 23.98 other 60i. I want to export a aaf with the media to be colored on davinci resolve. Resolve can handle mixed frame rates as far as I aware. So what is the best way for me to conform/ trancoded/ import the AMA linked clips in my timeline to 23.98? So I can then export a oaf and consolidate the media to a drive, to ship to the davinci system.
    Any help is most appreciated
    Mike Jeffs
    Video Coordinator
    BYU-Idaho
    Michael Phillips replied 14 years, 6 months ago 2 Members · 3 Replies
  • Michael Phillips
    March 19, 2012 at 11:13 pm
    If you transcode your 60i material while in the 23.976p project, it will create native 23.976 via the mix & match feature and now everything will be at the same frame rate – send an AAF from there.
    Michael
    Michael Phillips
  • Mike Jeffs
    March 20, 2012 at 12:10 am
    That’s what I thougt but when I did I got the same error in resolve. Maybe I did it wrong. Just to be sure what I did what right clicked on my sequence and chose consolidate/transcode. There I click on transcode set where to create the media (a separate media drive) selected dnxhd 135 and selected ok. When the transcode was completed I selected the new sequence and exported the aaf.
    When I import it in resolve I get the error Time extended don’t match.
    Mike Jeffs
    Video Coordinator
    BYU-Idaho
  • Michael Phillips
    March 20, 2012 at 12:16 am
    What version are you running? In 5.5, the Media Composer kept track of the sources and their original timecode rates with commments in EDL as to original rate, etc. In v6, the transcode will convert to local frame rate and there is no reference back to the original sources but should be as though the footage as always the rate of the sequence (23.976 in your scenario).
    If you make an EDL, does it look as though it is all 24fps source and record with what you have in your timeline? Does one event work?
    Michael
    Michael Phillips
