Activity Forums Adobe After Effects Conform 59,94 to 24
  • Conform 59,94 to 24
    Posted by Sergio Deustua on January 14, 2008 at 12:14 pm
    Hi everyone
    I have this movie shot in Varicam and edited in DVCPROHD 720p60, so it is in 59,94 fps.
    Now I need to make the transfer for film so I need it in 24 fps.
    So, what is the best method to do this?
    I
    Kevin Camp replied 18 years, 8 months ago 2 Members · 1 Reply
  • Kevin Camp
    January 14, 2008 at 4:10 pm
    you can just drop the higher frame rate footage into a 24 fps comp. that will drop out frames while maintaining timing.
    however, it will give the effect of shooting at a rather tight shutter angle and have less motion blur than if the footage had been shot at 24 fps with a normal shutter angle.
    you could try enabling frame blending (layer>frame blending>frame mix) to utilize the frames that you are dropping to help create a smoother, motion-blur-like effect. the draw back is if the movement is fairly great from frame to frame, frame mix will produce a stepped appearance rather than a smooth, motion-blur-like appearance that film/shot footage would have. so it really depends a lot on the footage.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
