Activity Forums Adobe Audition Conform 25fps audio at 24fps for DCP
  • Conform 25fps audio at 24fps for DCP
    Posted by Rousselos Aravantinos on August 21, 2011 at 6:27 pm
    Hey gurus,
    here is my case:
    I have a movie [originally video at 25fps ]
    My final output rendered is a tif frame seq. at 25fps.
    I need to deliver this project for DCP at 24fps.
    So to calculate the new duration for the audio i did a new comp. inside AE at 24FPS.
    Then i set my frame seq. at 24fps as well [ interpret footage / assume frame rate =24 ]
    So movie’s length at 25fps is 1:23:20:400
    and after this conform the final duration at 24fps will be 1:26:48:170
    So to match this new duration i imported my 25fps mixdown into Audition,
    and set the new final duration.
    I know nothing about semitones etc, but it sounds close to the original if i set the pitch shift as 1.
    pls check my screen shot:
    https://imageshack.us/photo/my-images/600/pitch.jpg/
    Now I’m rendering this Audio [ takes 3+hours ]
    and i notice that there is a warning at the right bottom of application saying there are Detected dropped frames.
    So what does really happening?
    Are my settings right?
    Should i stop the render and follow some other approach?
    best regards,
    Steve
    Rousselos Aravantinos replied 15 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
