Activity Forums Adobe After Effects Confining Trapcode Particles
  • Confining Trapcode Particles
    Posted by Tristan Nieto on August 2, 2011 at 9:56 am
    Is there anyway to restrict particles to a specific area, either using a mask or an alpha matte or something? I can’t just mask or matte it because that cuts through particles along the edges, which isn’t going to work for me.
    Not sure if it’s even possible,
    Tristan Nieto
    Visual Effects & Motion Graphics
    tristannieto.blogspot.com
    Darby Edelen replied 15 years, 1 month ago 3 Members · 2 Replies
  • Kevin Camp
    August 2, 2011 at 4:56 pm
    you can use air resistance (in physics>air) to slow the particles to a stop, if that’s what you need… but i can’t think of a way to fully contain them otherwise.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Darby Edelen
    August 2, 2011 at 9:03 pm
    If you set the Physics mode to “Bounce” then you can use a floor and wall layer to contain particles, but you won’t have access to the “Air” physics attributes.
    If you need fine control over where the particles travel then I recommend using the Motion Path feature in the Air physics mode.
    Darby Edelen
