Activity Forums Adobe After Effects configuring Dynamic Link
  • configuring Dynamic Link
    Posted by Marc Nibor on August 2, 2015 at 4:21 pm
    Not sure if this is a Premiere or AE topic…. but I’ll try here first.
    AE parts render VERY slow in Premiere, using only one core (12 are available) when I render a Project.
    I already did some searching but only found bits and pieces. The most important seems to be that dynamic link uses only one core – period. But this info was many years old – maybe something has changed since than.
    rendering realtime Previews of the AE parts in Premiere was also very slow. But seemed to speed up considerably once AE was closed.
    What I want to know is this:
    Is there any way to speed up rendering and use more than 1 core. (The info I found was quite old and maybe some dramatic changes were implemented ; )
    So if anyone knows a way how to speed up things please let me know.
    A confirmation that Dynamic link STILL supports only single frame rendering would be helpful too. Once I know for sure I can stop searching.
    Walter Soyka replied 11 years ago 2 Members · 1 Reply
  • Walter Soyka
    August 3, 2015 at 2:43 pm
    It’s not precisely one core, but it is just a single render process.
    Don’t forget with Premiere that you can now render and replace [link].
    You can also render some formats from After Effects with a project link that lets you re-open the AEP that rendered the output with a right-click and Edit Original in Premiere.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
