Activity Forums Storage & Archiving Configuring a Central Server with RAID for our Editors
  • Configuring a Central Server with RAID for our Editors
    Posted by James Kim on January 22, 2013 at 10:21 pm
    Hey guys,
    We’re currently in the process of upgrading our Post Production equipment and I’d love to get a feel for whats out there in regards to a central server system, where our editors can all work simultaneously (FCP/Premiere/Avid) and will be able to access all of our HD footage. Most of our footage is Prores 422 1080P so having a server that can deal with uncompressed HD would be great.
    We have 3 editors, 1 colorist, and 1 2D/3D Artist. We are all on Mac Pro’s and are currently using 5 slot edit bays with RAID. This has proved to be very cumbersome with the amount of footage being swapped around.
    Would love some input and direction. Thanks in advance to all who reply.
    Cheers
    Matt Stone replied 13 years, 7 months ago 5 Members · 9 Replies
  • 9 Replies
  • Alex Gerulaitis
    January 23, 2013 at 12:47 am
    [James Kim] “Most of our footage is Prores 422 1080P so having a server that can deal with uncompressed HD would be great”
    Could you elaborate on the “uncompressed” aspect? ProRes is a compressed format; uncompressed HD does change the requirements dramatically, nearly always necessitating FC-based SAN.
    GB Labs Space and Maxx Digital Final Share come to mind as possible solutions for ProRes.
    Alex Gerulaitis
    Systems Engineer
    DV411 – Los Angeles, CA
  • Bob Zelin
    January 23, 2013 at 1:49 am
    exactly where are you located James – in the US ?
    With AVID Media Composer, your choices are limited, even thought there are work arounds that can make anything work.
    Bob Zelin
  • James Kim
    January 23, 2013 at 5:35 pm
    Hi Alex,
    I just discussed with my editor, he says uncompressed HD would only be applicable for future use. As of right now we primarily only use Pro Res 422 HQ Footage.
  • James Kim
    January 23, 2013 at 5:37 pm
    Hi bob, we’re in Vancouver Canada.
    Also, we rarely use Avid save for a couple projects. It wouldn’t hurt us to isolate ourselves from Avid as the majority of our projects are FCP or Premiere Based.
    Thank you
  • Stephen Mckenna
    January 23, 2013 at 11:17 pm
    Hi Jim,
    I work for Studio Network Solutions (SNS) and based on your description I think our EVO server would fit perfectly into your environment. We have been designing SAN solutions for the media industry for 15 years now, and our products really shine in the kind of mixed environment you are describing. We have multiple solutions starting at well under $10,000.
    EVO works seamlessly with FCP/Premiere/Avid as well as any other production application you may use. All of your editors will be able to share footage and work simultaneously. EVO can also support uncompressed HD/2k playback in real time. You mentioned having one Media Composer suite, if you choose to go with more Avid in the future EVO also features native Avid Bin/Project Sharing – at no extra cost.
    We can mix and match multiple network topologies as well (i.e. 1GbE/10GbE, 4/8 Gb Fibre Channel) all within the same box. You can even add and/or change topologies as your needs evolve, for instance the EVO could start with GbE only and then add Fibre Channel or 10 GbE later down the road.
    In addition the EVO could easily direct connect all of your current users over any of the network topologies listed above without the need for a costly switch. You can direct connect up to 8 x Fibre Channel clients or 16 x GbE clients or 12 x 10GbE clients.
    If you would like to learn more about our systems or have any other general media SAN questions I would love to hear from you. I can also put you in touch with any of our existing clients for a reference or more guidance on your project. Please feel free to contact me at 314-775-8727.
    Sincerely,
    Stephen McKenna
    smckenna@studionetworksolutions.com
  • Bob Zelin
    January 24, 2013 at 10:05 pm
    Maxx Digital LOVES Studio Network Solutions, so why don’t you make your first call to Stephen, and then call the others, as recommended by Alex.
    And since I know that every one of the “competitors” reads this forum and the SAN networks forum, don’t you think that all of “us” should make Alex a dealer, as he is a top reseller in LA ?
    Bob Zelin
  • Alex Gerulaitis
    January 24, 2013 at 10:11 pm
    [Bob Zelin] “And since I know that every one of the “competitors” reads this forum and the SAN networks forum, don’t you think that all of “us” should make Alex a dealer, as he is a top reseller in LA ?”
    Was thinking the same thing – thanks for the kind words Bob. Will get in touch with the respective players. 🙂
  • James Kim
    January 24, 2013 at 11:00 pm
    Thank you Stephen, I will look into your solutions and contact you in the next couple days.
  • Matt Stone
    January 25, 2013 at 7:51 pm
    Hi James,
    At Maxx Digital we deal with shared storage on a daily basis. Our Final Share system is designed around simplicity. It is very easy for editors to use, and share files. We have the ability to connect via 10Gig/e and allow you to do uncompressed HD or multiple streams of Prores. Give us a call for more details.
    Matt Stone
    Maxx Digital
    714.374.4944
    Matt Stone
    Maxx Entertainment Digital
    3189 Redhill Ave. Unit B
    Costa Mesa, CA 92626
    Telephone:(714) 374-4944
    Fax: (714) 374-3404
